New owner of S$ needs wheel & winter tire advice
Any reason to choose a 16" over a 17" where snow tires would be concerned? (such as more cushion room to protect against potholes) Anybody used Audi OEM 5-spokes?
Thanks!
Thanks!
AudiWorld Expert
another reason...
for using a 16" is that a smaller diameter rim is usually also narrower, so you can safely put on a narrower tire (205 for example, vs. 225). Having a narrower tire improves the ability to cut through deep snow.
When choosing a smaller rim for your S4, you have to be extra careful to make sure it will clear your brakes. Not sure if the OEM 5-spoker will. I've got the 5-spoke replicas on mine, but my brakes are small (stock A4).
Re: New owner of S$ needs wheel & winter tire advice
I would recommend the 16" tires. You'll be much happier in snow performance and you probably won't notice much at all in dry road driving. It seems that the only reason to stay w/ 17" is if you want to use your OEM rims for winter and buy better 17" rims for the summer. Not only will the 16" be safer in the winter, but you'll save $$ on both the tires and the rims as opposed to the 17" models.
Depends on performance dry vs getting the job done.
Bit late in the season for you, but basically 16" will be less dry handling based than the 17", po it focuses more on basic performance and a bit less cost.
Going with 17" will have a better dry handling response and a better dry road feel. Snow perfromance generally about the same.
Feel free to call me & I can spec out your options between them!
chin
Wheels & Tires Discussion
11-06-2000 09:36 AM
BOBP
02-10-2000 09:20 AM
