Offset Question
<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fwheels%2Ftech%2Ftechpage.js p%3Ftechid%3D101%26amp%3B">Here</a></li></ul>
mean a 40mm wheel would stick out further on the car than a 35mm?
I am looking to get new wheels and would like to have the wheel fill the fender better.
allroad owners are limited to wheel type due to a 25 or 20et oem wheel. Many use spacers to allow 35 or 40et wheels to work. So the spacer is actually making the hub longer, reducing the offset of the wheel. Thinking through that, the lesser number is going to have more wheel to the outside.
all the offsets we discuss are in fact NEGATIVE mm. We just forget the minus sign.
So as you go from -45 to -35 to -20 you are in fact increasing the offse5t of the wheel's centerline from that of the hub's mounting surface, which is the definition of offset.
Grant
Grant
<ul><li><a href="http://www.1010tires.com/WheelOffsetCalculator.asp">clicky</a></li></ul>
MatthewZ
Wheels & Tires Discussion
12-17-2019 01:39 PM
why2kenny
07-14-2002 02:46 PM
Cam
10-21-1999 01:54 PM
