Proper way of storing tires?
Guest
Posts: n/a
Is there one? I just switched over to winter tires on my A4 and have my original set of tires and rims stacked up in my garage. Should I release the pressure or should I leave it as is at 32 psi. Should I bring it into the basement where it'll be warmer compared to the garage?
I know this is a small "****" thing to worry about, but hey, I love my A4 (including the tires!), as I'm sure most of you guys do.
Thanks,
Tim
Thanks,
Tim
Guest
Posts: n/a
Here's what I do...
Stack on top of each other, with cardboard or plywood underneath (so the bottom one's not resting on the concrete). I leave the proper pressure in the tires. I store them in the garage, but may get ambitious enough this year to haul them to the basement. Also, I label them as to where they came off the car (RF, RR, LF, LR), so I can rotate them when I re-install for the next season.
I did this for 8 years with my CRX snow tires and never had a problem.
HTH,
CraigB
HTH,
CraigB
Guest
Posts: n/a
I saw this on a car show on TV (maybe MotorWeek?)...
They recommended storing the tires standing up beside each other, resting on two pieces of wood, like 2 x 4's, a short distance apart so that the rubber was not actually on the ground.
It seemed to me that this might, over a winter, create indentations where the tire rested on the wood, and that a "flat spot" where the tire was on the ground might be preferable.
This will be my first winter storing tires, so additional feedback (besides Craig's) would be appreciated.
Mac
99.5 1.8TQTip
Mac
99.5 1.8TQTip
Imola Rolla
Pacific Northwest Discussion
10
12-10-2008 09:57 AM
|skolnick
02-03-2005 05:20 AM
Ed@mtl
Canadian Discussion
08-29-2003 08:08 AM
Lightweight-USPowah
11-23-2002 02:27 PM
Stoney
Wheels & Tires Discussion
08-02-2001 10:13 PM
