Rear Brake Pad wear
Hello,
I took my 201 SQ5 in today, it's at 20Kmi, and they indicated I need new rear brake pads/rotors. My rear pads are at 2mm, and my front are at 6mm. Is anyone else running into this? I don't think the pads should wear down that fast given I never drive on a track and just drive around town?
Anyone else experiencing this?
Hello,
It came up in an Acura chatroom that TSXs wore out rear pads faster than front pads - crazy, given the front weight bias of that car - and it was suggested that the stability control might be causing the rear brakes to wear more. And it's possible that the stability control came on "so often to cause this condition" because of the way people drive: pinch their turns = um, can't find an apex (sorry); perhaps the SQ5 generates a lot of understeer, or various low tire pressure conditions, or less performance oriented tire choices, maybe). I typically turned that car's stability control off if the roads were dry (because I didn't like sometimes having to fight the stability control in low gear/near full-throttle while turning situations), but my brakes just tended to last because I used to try to not need to slow down too much...and that 4 cyl Acura weighed as much as a V6 Accord.
englsh
01-23-2006 02:30 PM
tsrjaa
10-21-2005 05:12 PM
VTAutoXer
16
10-15-2003 09:37 AM
