Rim/Tire choices: opinions pls.
I'd like to upgrade the OEM 15 x 7" tires on my B5 A4 1.8TQTip and get a set of performance summer tires/rims. I have narrowed it down to 2 choices, both with 225/45/17 tires:
+ The Ronal R-7 (which are on sale) are considered a decent cheap wheel (some consider them heavy and soft). I would go with 17 x 8" with an offset of 45 mm (same as stock). The offset calculator shows 13mm less clearance on the inside and 13mm extra extension. Would the decrease in interior clearance cause any problems? Cost is $1096 +S/H including Pirelli Pzero Nero tires.
+ The Hartmann B7 RS4 replica wheels. Haven't seen much opinion on these in the archives (except that people think they look cool). I would go with 17 x 7.5 with an offset of 42. This results in 3mm less clearance on the inside and 9mm extension on the outside - is this a better fit? Would the matching tire be 0.5" narrower than the Pirelli? Cost is $1276 +S/H including Falken 512 tires.
Thoughts on which would fit better or is it a wash given that the numbers are less than 13mm?
Is one a better rim (forgetting aesthetics)?
For a little bit more $$, I am considering upgrading to the Goodyear Eagle F1 GS-D3 tires. Is this worth it?
Thanks,
David
Thanks,
David
Dgkula,
Before making a decision, check Edge Racing. You may find something you like.
Leo
leo@edgeracing.com
800-489-5353 x211<ul><li><a href="https://www.edgeracing.com">https://www.edgeracing.com</a</li></ul>
Leo
leo@edgeracing.com
Just pulled trigger on 17" A4 oem rim snow whls, but tires are 235/45, Do I need new tires? Other Qs
gideon-sf
Audi allroad
10
10-19-2006 05:56 PM
dgkula
06-05-2006 02:01 AM
tpmurray
10
11-08-2003 03:15 PM
