RS6/S6 aggressive fitment question..
what is more aggressive fitment for C5 S6/RS6???
i was told 19x9.5 +35 with 275/35-19... is that gonna rub???
also if i lower my car use Eibach or H&R Spring, will i got the Dynamic Headlamp range Error???
Unless someone haves exact same configuration of have gone through same exercise, it is hard to say...
Though with vag-com you can adjust your lights and eliminate range error (not the mechanical adjust)...
A customer of ours has tested a 19x9.5 +30 with 275/30/19 tires all around on a stock suspension RS6 C5 with no rubbing issues. +35 might not be enough inner clearance.
I'd still recommend going with a narrow tire brand if you do something this aggressive.
do u have a pic??? i really like ur 701 (advan RS) look~~~ saw ur web have 19x9.5 +33 that maybe the best fit, what tire size u recommend???
thanx
We have not yet tested the 9.5 et33 on an RS6. Basically we're just bringing in this fitment because a lot of the A4 guys have been requesting to run staggered setups.
If you are going to do a 9.5 setup I'd stick with either a 265 or 275. As I said, a customer of ours has fitted a 19x9.5 et30 with 275/30/19 all around on his RS6 with no rubbing issues. However it was an EXTREMELY close fit.
kreativecid
Q5/SQ5 MKI (8R) Discussion
16
10-04-2021 12:30 PM
ECS Tuning-Audi
09-30-2015 06:08 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-29-2015 11:59 AM
