slight vibrating at 75 plus....
just got new wheels and tires, Falken ST115, and I notice a slight vibration at 75 plus, Im assuming this is due to improper weighting during a balance. Is there anything else I should know that might be causing this? A break in period on tires? Ive never heard of anything like that, but then again Im no expert. Help is good.
AudiWorld Expert
1. Can be a out of round tire.
2. You can look to see if one tire has lots of weights added - if yes, have them rotate the tire 180° and rebalance.
3. Shocks and other suspension can be a issue.
4. Moving the tires front to rear can be a tool to see which tire is at fault.
I usually get my car aligned when I put new tires on. I would have that done and then if still there have the tires rebalanced.
This the most advance balancer available and will find tire and rim issues immediately.
docslacker
08-12-2004 04:59 AM
S4_Obsessed
11
04-13-2001 02:36 PM
