Some say yes and others no???
I've asked several times before and get about a 50-50 split on whether a 235/45/17 tire on a 8" wide wheel will rub at all or not on a stock suspension 2001 A4 1.8T Quattro. Then to make things tougher, how about the same tires on a slightly lowered set-up, say with Eibach/Bilsteins?
A small offset might cause you to rub the fender, but a large offset might cause rubbing inside the wheelwell or suspension. And then there's always the caliper rubbing situation due to a wheel with a thick outer rim.
ModDeprived, maybe you shouls search the forum for people who have the wheel/suspension setup you are looking at. If that doesn't work, at least find someone who has the same suspension setup and a wheel with the same dimensions as the ones you are interested in.
With an offset much above 35mm on 8" wheels ou will be VERY close to the suspension in front and rear.
With an offset at or below 35mm you will start to have problems in front with the wheel wel lips and liners depending on your springs, roads and driving habits. The interference will be when turning while the suspension is compressed.
Due to build variances on your car, the tire profil, the fitment of your wjheels.
If you want to push the size envelope then you should plan on "if I need to roll lip, then I will do it".
If not then go with the 225/45s & start driving![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Call me if I can help!
Eddie
Eddie
MiniMan
Audi Original "S" Cars
04-23-2007 12:10 PM
jaystizo
9
02-18-2003 10:34 PM
