strongly considering 19 inch. rs4 reps for my b7. i want them in black
Plus they only weigh 21.75Lbs each, they are 8.0" wide with an ET 30 offset which is as far out as you can go on a B7 A4. <a href="http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=282"><img src="http://shop.achtuning.com/ProductImages/images/product_images_hartmann/Hartmann_500x500_Audi_B7__Split_7_Spoke_Black_Forg ed.jpg"></a>
<a href="http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=282"><img src="http://shop.achtuning.com/ProductImages/images/product_images_hartmann/Hartmann_500x500_Audi_B7__Split_7_Spoke_Black_Forg ed_Angle.jpg"></a>
On Audis, the lower the offset (ET) is the further the face of the wheel sits from the wheel hub. ET 30 is as extreme as you can go without rubbing, ET 42 and 45 will be closer to the stock offset.
The hartmann forged wheels are priced at $600 per wheel, the cast wheels are $230-$330 each but are not available in black.
Tekk
Wheels & Tires Discussion
02-19-2009 01:10 PM
TISaint
Audi A3 / S3 / RS 3
07-03-2007 11:12 PM
Tomasz@Startup
01-03-2006 07:20 PM
