Tire Repair
Guest
Posts: n/a
Went out the other night to find that my right rear tire was looking low. Put some air in it and checked on it a few hours later, good thing I did. The tire was alomst completely flat. Question is, what is the difference between patching and pluging? I can't even find the hole in the tire, and I searched for quite a while. Should I attempt to find a place that uses one method over the other?<p>Thanks,<p>Becker...
Guest
Posts: n/a
I sure hope not! If that is the case, these Chicago roads are killing me, did the same thing last winter with my Eclipse. Fortunately, there is no visible rim damage, like there was with the Eclipse (the Eclipse rim still held air). Time will tell, my dealer said they will patch the tire for no charge, that's cool!
Guest
Posts: n/a
May be hard to spot, with the wheel on the car. For a patch, they remove the tire from the rim and affix a patch to the inside (preferred method). A plug is made of some thick string with some vulcanized (no...not you Spock) rubber goop on it. It's inserted fully into the pucture with a screwdriver type tool, pulled back and cutoff flush; I have plugged tires in the past with no problems (tread punctures only). Good luck!<p>CraigB
