Tires rubbing
Just put a set of 19 x 8.5 BBS wheels with 32et and 245/35/ rubber. the fron left tire is rubbing on road dips. If I go to a 235/19 will this eliminate the problem?
Depending on the vehicle, that shorter and more narrow size of 235/35R19 should help with the rubbing, yes.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR8&url=/tires/index.jsp">tires</a></li></ul>
If my ET32 wheels rubbed with BFG's, do you think ET35 would also? Will those 3mm make a difference?
Blau Flash
04-03-2006 10:45 AM
Achen
07-05-2005 09:58 AM
adog4ya
04-07-2003 03:39 PM
Can I fit 19x9 with 235/35 or will it rub also will the tires not really fill up the 9" wide wheels?
Quatime
17
11-07-2002 05:23 PM
