What is the world's most QUIET tire????
Guest
Posts: n/a
I know everyone talks performance, speed and handling. All this item are very important and I know how tires can change a cars personality. What would you recommend as the best tire if the most important consideration are:
1) Noise
2) Noise
3) Noise
4) Ride Comfort
5) Handling
6) Speed Rating
Just interested in seeing what is available as a quiet tire.
Roy M
1) Noise
2) Noise
3) Noise
4) Ride Comfort
5) Handling
6) Speed Rating
Roy M
Guest
Posts: n/a
Tire manufacturers use different size tread blocks around the circumference of the tire to quell resonances. So if you look at a tire, and the tread blocks are the same size all the way around, skip it if noise is your primary concern.
Noise or ride quality have never been big concerns for me, so I can't give you any specific makes/models. But anything labeled as a "touring tire" should be very quiet, and still have respectable performance for everyday needs.
Check out the Bridgestone Turanza Revo. I never used it, but I've heard good things about it from several sources (including Tire Rack).
Remeber, all tires represent a compromise.
High-performance tires perform great at the expense of ride quality, noise, treadlife, etc.
Snow tires are great in the winter, but at the expense of noise and dry handling.
All-season tires are a jack-of-all-trades-master-of-none.
And "touring tires" are a subset of all-season tires, but their compromise favors a comfortable and quiet ride over ultimate performance.
And they usually have good treadlife too.
--Peter
--Peter
TTOURN
Wheels & Tires Discussion
03-13-2003 10:04 AM
DesmoTesta
06-21-2002 03:38 AM
