Wheel depth - difference?
While looking for new wheels to replace my slightly bent MM Spiders, I fell in love with the Abt A11. It is a 17x8 wheel. Unfortunately, it is no longer available, but its near-twin, the A23, still is. However, the A23 is only a 17x7.5 wheel.
I will be running 225/45 Bridgestone S-02PP tires. How much of a difference will I notice in traction between a 7.5" wheel and an 8" wheel? I know that the "height" won't change much, because of the steel belts, but the contact patch will still be wider with the 8" wheel.
is the design rim for the 245/45-18 (anything from 7.0 to 8.5 is OK), so you will probably get better performance from the narrower rim.
In any case, though, the difference will be so small that you won't notice the handling difference. Just one psi off from the optimum pressure will have much more of an effect.
I didn't know that the measured rim width/design rim width was actually important for optimal performance; it sounded from the Tirerack text that they had to pick SOME rim to measure the tire width, and assumed that the MRW was whatever size the industry uses for that size tire. Good to learn.
I'm not AS concerned about looks, width-wise - yes, wider looks better, but washed would look even better, and that hasn't influenced me lately...
it might be worth the $$$ importing the rims for performance, but not just for looks. Thanks.
Assuming that you would be using a 225 tire on either wheel, if the wheel is 1/2" narrower, that means you have 1/4" more curb protection (1/4" inside and 1/4" outside.)
The tire sidewall will flex to accomodate different width wheels, within a certain range. But the tread width will remain the same, hence your traction will be the same. So from a performance standpoint, you are probably better off with the narrower wheel -- it is most likely lighter too!
If you want the LOOK of the wider wheel, you could always use a 5mm spacer to push your wheels further out.
But before you do that, check the offsets of both wheels. If the 8" wheel is ET42 and the 7.5" wheel is ET35, then they will appear the same on the car.
If they are both ET35 wheels, then obviously the 8" will stick out slightly more, and have a more aggressive look. If the 7.5" wheel is ET42 it should still look good. If it is ET45, you might want to think about a spacer.
Cheers,
Peter
Cheers,
Peter
iModTTS
TT (Mk2) Discussion
02-19-2009 08:45 AM
John
09-27-1999 02:58 PM
