B8 A4/S4/allroad VCDS Coding
Disable After-wipe of windscreen wipers
[09 – Cent. Elect.] [Coding – 07] -> [Dropdown] -> “x ** 8K1 955 119 ** WWS xxxx” -> Long Coding Helper -> Byte 1
Bit 3 – Remove check mark (1 = active)
________________________________________
Disable amber corner lights
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 – Set to 0 to disable amber side markers (U.S. vehicles)
Disable Key warning (keyless models)
[46 – Central Conv.] [Coding – 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
Disable LED ‘wink’ on turn signal
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 2 – LEDs remain at full brightness with parking lights (1 = active)
Bit 7 – Turn off LED-strip DRLs with indicators (1 = active)
Disable “Lights are on” Warning
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 5
Bit 3 – Set to 0 to disable “lights are on” warning when you open the door.
Disable NAV & Phone warning messages while entering data at speed
[5F – Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
Disable Seatbelt Chime
[17 – Instruments] [Coding – 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
Enable Adaptive brake lights
[46 – Comfort System] [Coding – 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
Enable Ambient Interior Lighting Control
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
Enable Automatic Gear selection shown in DIS
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic Hill Hold Assist ‘lite’
[03 – ABS brakes][Security Access – 16] (Enter code presented by program)
Bit 6 set to 1 to enable hill hold assist.
http://www.audizine.com/forum/showth…r-the-A4/page2
Enable Auxiliary ventilation
[5F – Information Electr.] [Coding – 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 – Auto HVAC] [Coding – 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Enable Battery meter
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 – Radio] -> Adaption -> Channel 39, add 16 to your value
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 – Instruments] [Adaptation – 10] -> Channel 77
change 0 to 255
Enable Double Disarm Beep
[46 – Central Conv.] [Adaptation – 10] -> Channel 63
Add 4
Enable DRL Selectable via MMI
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
Enable Euro parking lights that turn on signal at night
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 9
Bit 0 – Set to 1
Enable fog lamp to come on for the same side as that turn signal
[09 – Cent. Elect.] [Coding – 07] -> Long Coding Helper -> Byte 4
Bit 0 – Check the box or change :Bit 0 set to 1
Enable Front Turn Signals as Parking lights
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL’s by making the following change:
Bit 6 – Check the box or change :Bit 0 set to 1
Enable Gauge Test/Needle Sweep
[17 – Instruments] [Coding – 07] -> Long Coding Helper -> Byte 1
Bit 0 – Check the box for “Gauge Test/Needle Sweep active”
Enable Headlights on all the time
Bit 5 – Check the box or change :(Bit 5 Set to 1)
Enable Hidden menu in MMI
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the “Bootloader”
Enable Import CDs to MMI’s HD
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 “Copy/Ripping”
Enable Independent Fogs control with high beams
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 – Check the box for “Lap Timer active”
Enable Remote Operation Windows and Sunroof
[46 – Cent. Conv.] [Coding – 07] -> [Long Coding Helper] Byte 2
Bit 2 – Set to 1
Enable Rear Tail Lights on with DRLs
Bit 7 – DRL’s via Tail Lets Active (1 = Active)
Enable Release Parking Brake without putting foot on Brake
[53 – Parking Brake][Security Access – 16] (Enter code presented by program)
[Adaptation – 10] -> Channel 4 Set to 0
Enable Release Parking Brake without putting seatbelt
[Adaptation – 10] -> Channel 7 Set to 0
Enable Reverse mirror tilt
[52 Door Elect, Pass.] -> [Coding – 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
Enable Speed through MMI
[56 – Radio] [Adaptation – 10] -> Channel 02, Set to 1
Does not work if NAV equiped
Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 – ABS Brakes]
[Security Access – 16] (probably with login code: 61378)
Bit 3 – Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 – Instruments]
Bit 0 – Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
Enable VIM on MMI
[5F – Information Electr.] [Advanced ID – 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation – 10] -> Channel 48
Set to 255
Reset MMI
Set Audi parking system – Switch OFF Speed
[10 – Park/Steer Assist] [Adaptation – 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access – 16]
Set to 01 – Comfort, 02 – Auto, 03 – Dynamic or 04 – Individual
[Adaptation – 10] -> Channel 64
[Adaptation – 10] -> Channel 65
[Adaptation – 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer – Duration
[09 – Cent. Elect.]
[Security Access – 16] [Adaptation – 10] -> Channel 6
change to e.g. 500
Set Headlight washer – Cycles
[09 – Cent. Elect.]
[Security Access – 16] [Adaptation – 10] -> Channel 26
change to e.g. 10
Adjust Consumption in DIS
[17 – Instruments]
[Adaptation – 10] -> Channel 3
change 100 to xxx (see samples below)
Sample 1 – Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 – Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access – 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
Set Automatic Transmission Start Mode to D or S
[09 – Cent. Elect.] [Security Access – 10]
[Adaptation 10] -> Channel 64 – Stored Value = 218 = Starting mode is always D
Channel 64 – New Value = 00; Starting mode is determined by ADS selection at engine shutdown (Comfort and Auto=D, Dynamic=S, Individual=whatever you pick)
Channel 64 – New Value = 03; Starting mode is always S regardless of ADS selection at engine shutdown (opposite of stock)
Channel 64 – New Value = 11; Starting mode is S with all ADS settings at shutdown except Comfort where it’s D
Channel 64 – New Value = 19; Starting mode is S with all ADS settings at shutdown except Auto where it’s D
