Tech Article Title |
Author |
Date |
C4 A6 Flexible Brake Hoses |
Grant Lenahan |
2008 |
The following are my notes – and findings – after the ordeal
of replacing the seemingly easy and cheap rear flexible brake lines on a 1995
Audi A6 quattro.
Flexible brake lines are at all 4 corners of all cars. They
connect the brake calipers to the hard steel brake lines, allowing the wheels
to move up and down.
Over time they can become cracked and even develop bulges, indications of possible weakness and
failure.
New OEM brake lines can be purchased from a wide range of internet and physical parts stores for between $12 and $25 each. In most cases they have SUPERIOR longevity to the fancy stainless braided lines sold as performance add-ons, and are rarely
the culprit in bad brake feel.
![](pics/wheel29_image002.jpg)
New Flexible Brake Lines. Caliper fitting at right, receptacle for
Flare fitting at left.
Picture of flexible brake line, in place, on 1995 C4 – Right Rear
On the surface, this job looks easy. But a few gotchas exist. That’s why I wrote this piece. The key “gotcahs” are:
Flare
nuts and flare nut wrenches – more complicated than it looks!
Frozen
nuts of various kinds
Poor
documentation in Audi (Robert Bentley) “official repair manuals”. In fact, its often completely absent.
The mess.
First let’s look at
the overall layout. Refer to the picture above.
The flexible brake line begins at the caliper, where it screws directly into
the caliper. This can be removed with a 14mm open end or combo wrench. Typically, it does not seize, and a flare nut wrench is not
required. In fact, you often could not fit a flare nut wrench over the reinforced shoulder of the brake line anyway.
Flexible brake line where it screws
into rear caliper (14mm wrench)
The flexible brake line continues, about 10”, to a point where it joins the
fixed steel brake line. This is often hard to see, being partly behind a
metal flange. The hex body of the flexible brake line slips into a hex-shaped hole in a metal hanger (welded
to the underbody). This hanger holds the line in place, and prevents it
from spinning. A flare nut on the steel brake line threads into the end of the flexible brake line (“hose”)
and secures the flared compression fitting of the steel brake line to the flexible one. A spring clip
completely encircles the flare nut’s body, pressing against the flare nut on one side and the hanger on the other, holding the brake line in the
hanger. The spring clip can only be removed once the two lines are separated.
The Flare Nut (11mm) – where the steel
and flexible brake lines meet.
note: hanger and spring clip securing them to underbody of car
This
flare nut (shown in the picture immediately above) is the primary cause of
difficulties in this job. It is very, very soft metal. Worse, the flare nut can seize due to
corrosion. Consequently it is
highly susceptible to rounding, leaving you in a bit of a pickle, since
once it rounds, it is almost impossible to get out without destroying both
the flexible line (brake hose) and the steel line. My advice – don’t get into that pickle
in the first place. Use lots of penetrating fluid ahead of time, do some
tapping, and above all, get a rally good flare nut wrench, They are not
all created equal.
If you
do wind up in this pickle, you can buy modular brake mine form most good
auto parts stores and bend it yourself with a tube bending machine. After
vice grips and all the other “sure sire” solutions failed, I cut the old
line off, flush with the spring clip, with a sawzall and a bi-metal blade. I bent the
new line ( it took me two lines, one destroyed to
get it right) and all was well. But as said above, a $20 top-quality flare
nut wrench would have solved all this anguish.
Ugly, ugly, ugly. Nothing’s taking this nut off without a
fight and likely a destroyed brake line.
Once
rounded, this nut began to literally disintegrate as pressure was applied with
channel locks and vice-grips
The old flare nut, cut by Sawzall
The
new brake line, bent to fit. Expect to, ahem, practice ( aka, wreck stuff)
Flare Nut Wrenches
The flare nut is a typical 11mm nut, as it also is on VWs, BMWs and Porsches, among others. Seems pretty simple,
right? Wrong.
Since it is so soft, a special wrench is needed to turn it,
called a flare nut wrench. This is commonly available, and looks like 7/8ths of
a six-point box end wrench, with just enough opening to get around the brake
line. Flare nut wrenches are far better
than open-end wrenches - - of any quality - - at turning the flare nut without
rounding it off. But that’s not the
whole story.
Flare nut wrenches are good, but on a particularly difficult
nut, they can fail too. I had a flare nut socket (on a 6” extension) round off
a flare nut, causing me tons of agony – once they round, they may disintegrate
as you try to grab and turn them with channel locks or vice- grips – not fun.
Don’t get there in the first place.
Two wrench manufacturers have metric flare nut wrenches with
patented head designs that drive the flats instead of the points/ tips. They
both claim to be able to exert 50%-100% more torque without damage to the flare
nut. In practice they work. Snap-on makes an 11mm “flank drive®” flare nut wrench
for between $30-50 (ouch). S-K makes an
11mm SureGrip® flare nut wrench that sells for
between $11-16 (much better). Get one of the two. I bought the S-K and it works
great. I would avoid the “well made”
tools, even from prestigious names, that don’t have these patented designs.
It’s the design, not the pretty mirror polish nor the precision forging, that makes these tools stand-outs.
Close-up of (3) 11mm wrenches. If you look closely, you can clearly see
the difference between a normal and a
flare nut wrench, and the difference between a flat-sided wrench ( the socket)
and a SureGrip® wrench ( the S-K).
I believe that a little penetrating oil, and a really good
wrench would have spared me lots of trouble, and will spare you trouble.
The Mess.
When you open up brake lines, you can make a mess. And brake
fluid is somewhat messy. The best advice
I have is:
Before
you start, put a piece of cellophane under the brake fluid reservoir top. This
makes a seal and the vacuum will minimize brake fluid flow.
Put
rags under the openings. You will get only drips and small dribbles, or at lest
that’s all I got.
Have
some plastic baggies and a rubber band or twist tie to close off the end. You
might also stuff a golf tee in the line
Bleed me.
Don’t forget to bleed the lines. Better yet, flush out that
old, water-absorbing brake fluid.
I hope this was helpful,
Grant
